Running open Shortys?
Guest Pegasus76
Guest Pegasus76
I am changing out the exhaust that the previous owner used...I bought competition headers 1 5/8" primary tubes, my new headers look similar to the old ones but the flange just doesn't want to line up. So I might hhave to run open shorty's for a while until I get some more money. Would that hurt the car at all if I ran open shorty's...I know long tubes are fine considering the tubes extend under and out past your engine bay. So would open shorty's not be a good thing?
Guest greimann
Besides the gad awful noise, the heat that may cook your wires and hose, and the potential of death by asphyxiation on fumes, it shoud be OK.
I wouldn`t risk it nono.gif If you think you will need new exhaust anyway, just cut the pipe off under the pass compartment, bolt up the flanges, and use some expanded pipe and clamps(shouldn`t be more than 10-15 bucks) at the cut to reattach the tailpipe. It should buy you some time, and extend your life expectancy(and possibly save some brain cells) ;)
Guest 240Z_72
I like the above suggestion, that would be a cheap, temporary fix. But...you can probably find a cheap shop to weld it up for you for peanuts. Even if you do go down to just headers like I recently did, it's real easy to put some 5-6' straight pipes on and bend them out behind the doors. I did that myself, then had a shop weld in some glasspacks (they basically sit under me) for $80, took about an hour. This ain't quiet by any stretch, but keeps me from getting pulled over.
