Guest Fast Frog Posted December 16, 2001 Share Posted December 16, 2001 Actually it's not the FI itself. It's where the top portion of the inj fits into the alum fuel rail "secured" by an O ring which is supposed to hold the top portion of the inj snug and keep it from leaking. Well the rear passenger side 2 FIs leak thru the top around the O ring. Leaking, like this, happened a couple of yrs ago when I changed out one of these inj and cinched the rail too tight and part of the O ring actually popped into the fuel passage. I had to put a shim between the rail and the manifold so the O ring wouldn't slip into the fuel passage when the fastener was tighten. This solved the prob until recently. Now these 2 injs are leaking again!! Will slightly fatter O rings solve the prob?? IS THERE a sealant that's gasoline "proof" that I can use inconjunction with the O rings? Any help will be greatly appreciated!!! Rick Quote Link to comment Share on other sites More sharing options...
Owen Posted December 17, 2001 Share Posted December 17, 2001 Maybe the o-rings were damaged the first time? Did you look for replacement o-rings? Owen Quote Link to comment Share on other sites More sharing options...
