Aluminum fuel line
Thanks for the replys so far, I have some stainless line I thought about using but I have AN aluminum fittings. I am concerned about the flare between the ss and aluminum leaking.
Is aluminum fuel line ok for fuel injection?
Just take care in mounting it properly knowing it's weakness is in fatigue & wear points for such use. So isolate it well with rubber mounting points. It's easy to use but if I had the option between either alum. or steel installed (ie. no work on my part), I'd choose the steel.
