Need throttle body info
Guest blue73z
Guest blue73z
I need a 30 to 40 mm diameter throttle body with as few accessories on it as possible; only TPS and cable wheel. Does anyone know off hand what type of car or motorcycle might have such a thing so I know what to look for when I go visit the junkyard(s) on Thursday?
Aaron
Guest blue73z
This is what I'm looking for:
-150 CFM
-single bore
-doesn't have to have a TPS; that can be added later, but would prefer not to
-doesn't matter if mounts vertically or horizontally
The reason the stock won't work is that the stock engine had four, the engine must be converted to a single TB as per rules.
Most important factor is the flowrate, everything else can be made to work.
Thanks,
Aaron
