first stealth ram dyno results
grumpyvette
http://www.chevytalk.org/forums/Forum12/HTML/000534.html
now remember this is PURE bone stock add a cam and headers, etc and the extra AIR/FUEL flow CFM of that STEALTH RAM will easily get you 100hp+ over a TPI intake with the same parts, got questions TALK TO DOUG,(one of HOLLEYS ENGINEERS ON THAT PROJECT) over at CHEVYTALK.COM tell him GRUMPYVETTE TOLD YOU TO ASK HIM, this intake is way better than most thats obvious, think how lousy a tunnel ram would work on a pure stock engine, the STEALTH RAM MADE 63 more hp on a stock engine! think about it!
_______
torque x rpm /5252=hp sooooo! he lost 9.7 ft lbs of torque at 3400rpm and gained 63.63 ft lbs at 5200rpm, in effect he gained torque and hp from 4400rpm and up and the worst he did was loose 9.7 ft lbs at 3200rpm
IP
keep the rubber side down and the fiberglass off the guard rails
