fl327 Posted September 26, 2002 Share Posted September 26, 2002 im checking out this guys used setup its a version of sds that doesnt run the coil packs, it uses a distributor still, im wondering how can i still run distributor if i go with it, im using eccs and timing is ecu controlled, hes asking a fair price i think but how im gonna use the distributor is a mystery to me, would i have to go to na zx distributor and manually do timing, im not scared of that one, but i like how the computer keeps things in check pretty good, besides lack of spark control and timnig by ecu, its the same setup i believe as most of the sds guys out there, what you guys think? Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted September 26, 2002 Share Posted September 26, 2002 I'm using that system on my turboed 78Z. I use the n/a distributor with vac advance removed set at 22 degrees initial which gives me 39 total with no boost. You'll have to run a MSD BTM to retard timing under boost. I have mine set at 1 degree retard per 1lb boost on 94 octane pump gas and have no detonation issues at up to 18 psi. It's not as adjustable as the coil pack systems but it's cheap-n-easy and will do the job. Quote Link to comment Share on other sites More sharing options...
Cyind Posted September 30, 2002 Share Posted September 30, 2002 Go read at sdsedi.com and you will see the kits and you can also read the pdf install man. I read teh one using the coilpachs which explains in great detail... Quote Link to comment Share on other sites More sharing options...
