Guest Anonymous Posted October 17, 2002 Share Posted October 17, 2002 i pulled in the yard one day an cut the car off an it won't do nothing but idle.i have to spay starting fuild in it to get it cranked .i have changed fuel pumps an filters,control unit,fuel relay,it look as though when i checked my injectors with a test light that both sides of the wires are staying hot all the time.i'm really confused here,was running prefect then to crap ,please help Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted October 18, 2002 Share Posted October 18, 2002 Does it idle good or bad. What happens when you give it gas? Is there black smoke coming out of the tail pipe. I suspect either you have a bad fuel pressure regulator, or the connection between the Ecu and the harness needs to be cleaned. Brake fluid works wonders there. Also hit the connection between the harness and AFM. Quote Link to comment Share on other sites More sharing options...
