Guest TAlchemist Posted November 1, 2002 Share Posted November 1, 2002 ok i got a problem. i am trying to get my engine running this weekend and i am reconnecting all the wires and harness. first problem is the injector wiring, all the clips are gone and broken...i have new pigtails but need to know how to find the order. second and important, in the haynes diagram there are 2 lines running to the battery has a fusable link inbetween. one line is + the other is -. when i removed the old battery and post the + post had 2 lines that came out of it and were crossed together and run tot he ecu. should one wire go to + other to -? one is red the other blue. i really need to know so i can get the car running. thanks Quote Link to comment Share on other sites More sharing options...
Tony240ZT Posted November 2, 2002 Share Posted November 2, 2002 The harness should layout in a way that sets up the injectors correctly. I think the haynes manual has the actual colors for each, but really it doesn't matter. They all get fired at the same time. Quote Link to comment Share on other sites More sharing options...
Guest Ian turbo240 Posted November 2, 2002 Share Posted November 2, 2002 If you are wiring up the 280ZXT f/i, then the two wires going to the battery are both to the positive terminal. The grounding is taken care of on the intake manifold. Recheck your wiring diagram. Ian Quote Link to comment Share on other sites More sharing options...
Guest TAlchemist Posted November 2, 2002 Share Posted November 2, 2002 well it is a na and the haynes manual says + and -, could be incorrect....all those fi wires and hoses are tough. thanks for your help, i will try and get it all worked out..... oh and if you could do you know where the vacuum hose from vac advance connects to? or hose from fpr? if i get that all worked out it may start Quote Link to comment Share on other sites More sharing options...
