1974.9? 1975-76 efi fuel tank
Guest Anonymous
Guest Anonymous
I have a late 1974 260z and I am planing to go with efi for turbo setup, Is my gas tank good for fuel injection? My tank look the same as a 1975 efi tahk from the outside, is the inside different, whats the difference? Is it the same tank?
Thanks!!!
my guess is that your car is carbed? my 280 was a late 74 and it was fine but it was factory efi from the start so the turbo swap was real easy, but if you have stock dual carb setup odds are it will not be the ideal for efi fuel tank.
Yeah, the very early 280z tanks should swap over with no problem. They have baffles in them so that the fuel doesn't move away from the pickup as easily. If you have the tank to swap go for it, there are other options, but that's probably the cheapest and most reliable route.
