Z-Dreamer Posted February 9, 2002 Share Posted February 9, 2002 My engine builder suggested using the New Holley 4500 Dominator HP Pro Street 750cfm carb and a Super Victor with the Pontiac Motorsport heads I've got. So what do you think? I see in the Jegs catalog that it has no choke! Will this by a problem? My Z will be a fair weather/weekend ride only. Thanks Mark Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted February 9, 2002 Author Share Posted February 9, 2002 bump Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted February 10, 2002 Share Posted February 10, 2002 thats not a bad idea but the cost might be quite a bit higher than a standard super victor intake and a demon 750 cfm carb. yes the flow path is better and the hp will be slightly higher with the dominator type set up ,(and the visual impression when you open the hood will be great with the dominator series carb) and no the not haveing a choke will not be a big problem on a fair weather only driven car.(BTW you will most likely need a hood scoop for hood clearance) Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted February 10, 2002 Author Share Posted February 10, 2002 Thanks Grumpy! Hood clearance is going to a issue since I'm going for the sleeper look. Mark Quote Link to comment Share on other sites More sharing options...
