David K Posted June 5, 2002 Share Posted June 5, 2002 i went from fuel injection to SU's. now i have this old fuel return line that goes back to the tank. do i still use that? what do i do with it? i cant find anything on the SU's or the manifold to hook up a return line to. Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted June 5, 2002 Share Posted June 5, 2002 Keep it and cap it off. If you need to hook up a bypass fuel pressure regulator then you are all set. Also, if you reinstall your EFI into the car to get it SMOGGED, then you will be glad it is still there. Quote Link to comment Share on other sites More sharing options...
