I want to do a n injected Chev Z swap need advise
Guest juliangall
Guest juliangall
I just bought a 1977 280 Z that was made into a convertible. I want to do a v8 swap, and I have an opportunity to buy an 1986 Camaro complete car that has the injected engine and all equipment along with a 700r4 trans. Am I looking for trouble by doing this type of engine instead of the carborated engine? I can use some help and advise.
Thanks
Julian Goldberg
The 700 fits a bit tight and needs a diff. mount for the tailshaft, the rest is no biggy. Take care removing the wiring harness as to not break any of the GM clips, is it TBI??? 305 or 350??? Would love to see some photo's of the convert. if possible. Looking at chopping mine next month. GOOD LUCK and go for it man 2thumbs.gif2thumbs.gif2thumbs.gif
You are certainly headed in the right direction with the donor car! (Did Tim just say that? smile.gif )
Buy the JTR Chevrolet TPI & TBI Engine Swapping Manual. Also, you'll want the JTR V8Z conversion manual as well if you don't already own a copy. Since you have gone this far, just keep forging ahead and do the EFI swap. You'll have a better, more consistent and reliable setup when its done. Good luck! smile.gif
Davy
