What Carburator is best?
Guest Pegasus76
Peg, match that high performance 750 carb to high performance cam, heads and exhaust with high compression.If your bottom end of the 350 is mild or stock you maybe better off with a 600 cfm carb. 750 cfm is natuarally suited to 400+ cubic inches
Guest Pegasus76
Sup guys, I am thinking about purchasing a 750 Street Avenger for my 350SBC. I want to be able to run my car to the fullest smile.gif I just wanted to know your opinions on the carb and if there is one out there that will improve my car's performance better than the Street Avenger can. Thanks
Guest Pegasus76
Thanks Tomahawk...I'll have to look into that a lil more and figure out which Cam, and intake and exhaust to get...Right now I do not know what cam it has in there but I have a weland Stealth intake and dual exhaust out of hooker competition shorties into 2 turbo mufflers and 3 1/2" tips.
Aren't the double pumpers a lil "eh"? I thought the carbs had better gas mileage and they are easier to tweak with and rebuild.
Keep in mind that a V8 Zee revs very quickly. My young friend Nate has a mild built 305 Hybrid with a mid range cam fed by a 650 double pumper blowing out shorties and inadequete glass packs.A very lopey idle but consistent.Very good running engine. The car does not with a kitted Turbo 350 tranny smoke em off the line easily but at around 3500 RPM the car is a ball of fire pinning you to the back of the seat..
