SU vacuum port question
Lockjaw
Yo. Its just a piece of brass tubing pressed into the aluminum of the carb body..........putting something else in there (that is a good fit), should not be a problem. The only issue I see is that the brass piece has a specific sized oriface (hole) that restricts the vac. My guess is you need to match that. Don't have a spare junk carb lying arround that you can steal from?
What I am curious as to is why you are not having issues with the way your car runs. If the port is sitting open you should have a vacuum leak, no?
Brett
