Trip webs what size jets?
40MM Webber carbs w/ 34mm chokes, TWM manifold
1983 280 ZX Block (F54 w/flat top pistons)
1972 240Z Cylinder head (10.4 to 1 compression ratio) ported & matched
Crane Cam (272/282 duration, .450 lift)
2.5 exhaust
the jets are set so wrong on this its washing the oil off the sidewalls and burning that with it .. bogs down when stomped on gas etc =( .. please tell me what size the ones in there i have no idea i havent looked but they are wrong obviously ( orig owner said was running rich for nitrous , i just think the moron bought the wrong jets cause its really bad )
thanks for the help in advance you studs.
Syndicate
These are some "in the ball park specs"
* NOT KNOWING YOUR SETUP, HOW YOU USE THE CAR THIS IS JUST A RECOMENDATION *
* You really need to go thru and inventory what is installed now *
Chokes - 30,32 mm
Emulsion tubes - F-11
Main jets - 125,130
Air corrector jets - 160,170
Accelerator jets, idle jets you need to see whats installed!
Webers are not hard to set up IF you understand how everything works together!
I would recomend you find someone in your area who knows the carbs AND get yourself a weber book or 2, read it, understand it!
I have 1 book from BTR Engineering Limited(they are in Austalia)(try a search on the web, I`ve had this book 4 about 12 years) that I think is the best! It`s title is, Weber-Guide to parts and tuning
You can do some damage if you don`t get thing close and then it`s a matter of some fine tuning!
Thanks! App the help guys unfortunately i have todo it my self argh! noooo no good carb places around here .. and i just got outbid on the other car i wanted =( damn
