Guest Tht1KSguy Posted November 1, 2001 Share Posted November 1, 2001 Alrighty... i wish i could say my Z was having this problem but it's not that far along. Last week my daily driver ('94 Cavalier) decided that it didn't want to idle upon startup (doesn't matter whether it's a cold or hot start) so i have to drive w/ both feet (it's an automatic) for awhile until the car decides it wants to run normally. I get no check engine light or decreased mileage, just won't run right. The weirdest part of it is that it'll be fine one day but not the next or from hour to hour. Also odd is that i would normally run the codes in the computer by jumping the little connector under the dash, but it doesn't do anything when i do this. Unless someone has a better idea i'm going to replace the idle air control motor and see if that cures it. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted November 1, 2001 Share Posted November 1, 2001 It could be your MAS air, the thingy with the heated wire between the filter housing and intake. With my old Baretta I had the same problem with my idle, it ran rough because it was in "limp mode", to get you home or the shop. Quote Link to comment Share on other sites More sharing options...
Guest Tht1KSguy Posted November 3, 2001 Share Posted November 3, 2001 Alright... how am i supposed to work on something that when i have the time to work on it, it shows none of the symtoms as before? Since Tues the car has been running fine again. I think i may put the voltmeter on the throttle position sensor on Saturday and see if it's flakey. The engine runs fine at any time but idle when it's not working right, so that makes me think the TPS might be the culprit. Aren't computers wonderful... actually i'll take EFI anyday compared to carbs which i know negative zero about... that should make tuning fun on my Z when it's ready. Anyone want to give me a $2000 "grant" for EFI for the Z??? Quote Link to comment Share on other sites More sharing options...
