Guest Anonymous Posted December 2, 2001 Share Posted December 2, 2001 hI GUYS just put a 400hp 350 in my 300zx and i need to know how to hook up the tac and temp generally im wondering anbout the wire colors in the dash. My gages are digital and i want to have the tac working weither it be acurate or not. just for looks you guys know how it is.i have figured out the speedo considering that i have the eletric drive 700r4 i had a 280zx with along gages and i hooked then into the instrument cluster from the sensor but the 300zx is new to me and i havent had a chance to run the wire colors down right just yet all help will be appreciated thanx Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted December 3, 2001 Share Posted December 3, 2001 Unless someone here has first hand knowledge about this you may be on your own on this. Not to many here have done the 300ZX V8 swap. Do you have a repair manual for the 300ZX? If not you should get one and trace the wireing diagram. Good luck! Quote Link to comment Share on other sites More sharing options...
GetInTheZ Posted December 6, 2001 Share Posted December 6, 2001 Hey, I am fixing to start a conversion for my 85 300zx and was wondering if you could answer a few questions for me. First did you have any problems off hand with fitting the engine in and, did it take any big mod's. What kind of transmission did you use and did you have to rework the driveshaft. Did you have the e.c.u. reprogramed or did you just leave it dangleing. As for your dilemma if you wanted to forgo the digital dash you might try to put a needle type in there and not have to worry about sensors or tracing the wire. Quote Link to comment Share on other sites More sharing options...
