Guest Anonymous Posted January 10, 2002 Share Posted January 10, 2002 ...just had my engine rebuilt....heater didnt work so i moved the vac lines @ the magnetic switch canister .. ..... got the heat/defrost,cruise working and running well...but it idles @1200 cold then goes to 1000 after it warms up... it idles @ 700/750 only if i take a vac line straight to the fuel pressure regulator....how should i test this? thanks...s Quote Link to comment Share on other sites More sharing options...
Guest super280z Posted January 10, 2002 Share Posted January 10, 2002 there's an idle adjustment screw on the TB. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 10, 2002 Share Posted January 10, 2002 ..i dont have one in my car....(there arent any adjustments @ all)..its all done (or not) by the ecu and/or aac valve...i have heard the new (replacement) aac valves have an adjustment valve..that might get it to idle @ 700 (compensate for whats wrong)...but i'm afraid that might not be the real reason its idling incorrectly...s Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 11, 2002 Share Posted January 11, 2002 theschmaydee, I am working on my heater air conditioning as well. I read that there is an idle adjustment done by the air conditioner, to raise the ide rpms only when the air conditioner is on. heres a quote from my 1980 zx na factory service manual: "*F.I.C.D. Fast Idle Control Device increases engine revolution when system is ON. This device is nonadjustable" the star is a reference for the picture up above of the layout of the system, where it is labeled F.I.C.D.* It seems to me that maybe this could be your problem. Do all of the ventac controls work properly? Just some thoughts, Kris Quote Link to comment Share on other sites More sharing options...
