bad Heater core = Overheat
Yes, you're loosing pressure in the cooling system through the bad heater core. Now if you bypass the core (connect the two heater hoses together) and there isn't any other leaks, you should be able to drive the car. If it still over heats, there is another problem.
My car has started to over heat. I know that the heater core has gone bad. Is there a connection between the heater core and the car overheating problems?
