HELP!! WIRING WOES ON 71 240 GOTTA GET IT TO THE PAINTER
Guest LAYTON
Guest LAYTON
here i am going on vaca leaving tues its sat night
trying to finally start my 240 iv rebuilt everything !
the car was a bare shell when i got it last summer i did not pull it apart !
i was starting to feel pretty good about it did all hot rod stuff to it as a peiced it together all i had to do today was put my fuel lines on the tripples ,wire the elctrnc dist and bolt in the seats ,and the battery a fuseable link
got the dist done ,the fuel lines ,the fusable link put the key in and the wires at the ignition swicth get really hot and so dose the harness behind the glove box (were it has no connections at all im i little stumped it only dose it when the key is all the way on not when in the acc position any help ,experience or ideas would realy help i was intending on giving it to the painter before i leave besides this and seats its ready for gas all the harness conections apprear obvious but i have looked at a hayenes wiring diagram and have a huge head ache
help ,,,,,,,,,,,,,,,,,,,,,,
Wiring Problem
Your problem is not clear enough described.
But I would not recommend you to drive the car
with this problem to the body shop. A fire could
possibly occur. You could tow with the battery
disconnected. Your problem is a short in the
part of the wiring that would be "hot" with the
key in the "on" position. The "accessory" postion
of the key would only activate accessories radio,
etc. Wiring is either hooked up wrong or htere is a short somewhere. I would backtrack all
"hot" wires from the ignition switch to their
end. As the wiring gets hot, you might be able
to actually feel the short. GOOD LUCK!!
Sunny
