alternator woes...
I am triing to fix another persons wiring for the conversion to ir alternator. When you make the pigtail from the old voltage regulator where is a good spot to find a true 12v source? Next what do you do with the old connections that hooked to the alternator? Do you just leave them unhooked? I have the flat 6 wire connection not the round one. I think that will do it for now. Thanks, Pete
