Clutch plus leaking canister=bad!
Okay, went to start the 1980 280ZX, and theres no pressure to the clutch, and upon opening the hood, a small caniste on the passengers side is spewing forth a foul smelling liqued. The Car will now not shift into any gears.
Any thoughts?
Guest greimann
Your slave cylinder is toast and the clutch fluid had water contamination, allowing anerobic bactera to grow. This bacteria gives off a nasty odor. Luckily, slave cylinders are cheap for this car.
