Help with cigar lighter
Guest greimann
Wise crack #1:
Are you inhaling as you try to light your cigar? They usually don't go out when you do that. :D
Wise crack #2:
You are supposed to put cigars in the lighter, not fuses!
Wise crack #3:
Sincere attempt at help:
Is the heating element in the socket when the sparks fly? If so it may be shorted. Try installing a fuse without the heating element installed.
