Want electric fuel pump
Guest uberhahn
Guest uberhahn
Ok, i'm tired of starving my L28. I want to go to an electric fuel pump. The '85 RX-7 should do, and should be pretty cheap.
I need some help in installation, primarily wiring. Thanks for any help.
bk
Uh, + to a 12V source, - to ground basically...
However, I'd get a relay in there, and have the switched 12V source trigger the relay, then run a decent sized wire (12ga or 10ga) to the fuel pump from the battary (but through the relay).
I found that I was starving at 5000+ on just the mechanical pump alone, so added in an electric pump near the tank... problem solved.
