Guest Russ240z Posted February 13, 2002 Share Posted February 13, 2002 Does anyone run the Vic Jr with 1" tall plenum and the stock hood? I will be using the JTR setback and a 4150 holley. Quote Link to comment Share on other sites More sharing options...
Guest chevsun Posted February 14, 2002 Share Posted February 14, 2002 I run an edelbrock carb on the RPM intake and had to cut the air cleaner base by 5/8" to clear the hood. Quote Link to comment Share on other sites More sharing options...
v8zed Posted February 14, 2002 Share Posted February 14, 2002 Yes I use the victor jr. with the extra tall plenum and a stock hood with a 2 inch cowl induction scoop I can just get it closed. It will NOT work without cutting the hood. The standard victor jr. will work with a stock hood and the JTR motor position. Dennis Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 14, 2002 Share Posted February 14, 2002 i have the regular vitor jr with two 1/2 " nitrous plates,4150 carb and a drop base 3" aircleaner only rubs the hood a little when the motor moves Quote Link to comment Share on other sites More sharing options...
Guest Russ240z Posted February 16, 2002 Share Posted February 16, 2002 Need more feedback on hood clearance with Victor Jr intake with extra 1" tall plenum. So far I've got differing opinions (counting the standard vic w/spacers). I don't want to cut the hood. It kills the sleeper look. Quote Link to comment Share on other sites More sharing options...
v8zed Posted February 17, 2002 Share Posted February 17, 2002 z350 is right if you use a drop base air cleaner. I had one on at first but it only gave me 1 inch between the carb and the top cover and I felt the air was not flowing in as smoothly as I wanted. I changed to a 10 inch K&N 3 inches tall and added a cowl induction scoop. So much for the sleeper look! Dennis Quote Link to comment Share on other sites More sharing options...
