CARB TURBO
Guest Look A Z
Although that is one of the better carb turbo setups (draw through), carburated turbo setups aren't that great. I had a Crown kit on my L24 (used a singe SU instead of the Holley), and turbo lag was plentiful, and so was detonation. I was running stock L24 CR with and E88 head. I dumped it and went with an L28ET setup with aftermarket FI and have never looked back. If you want something to fiddle with, get it. Mine was very tempermental. I had to run the timing retarded to prevent pinging, and even then on ocasion it would ping. The bottom line, I spent more time screwing with it than actually driving it...
Pete
