Guest Anonymous Posted February 20, 2002 Share Posted February 20, 2002 so can anyone tell me where i can get info on a chevy 350 swap into a 91 300z Non-turbo any links or info will be most thankful Quote Link to comment Share on other sites More sharing options...
Len Posted February 21, 2002 Share Posted February 21, 2002 I'm sorry I can't help you on that one. If the car's engine is really bad I guess maybe look at your engine bay as compared to a 71 to 83 280's engine bay. If they are close; then start cutting, pulling, welding and slashing! But if I were you I would first fix your 91 up as best you can. Then sell it. You will then have enough money to buy two old Z's. One as a daily driver along with another with either no engine or a bad engine; you can turn around and do the HybridZ thang to! Len Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted February 21, 2002 Share Posted February 21, 2002 It's been done (seen a carb'd 383 powered 2+2 in person on several occasions) but IMO... save a good car for a good engine... put the V8 into an older Z. Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted February 22, 2002 Share Posted February 22, 2002 Check it out: Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 26, 2002 Share Posted February 26, 2002 I was just curious why everyone is against this swap...granted, it would be more expensive, but not by much...the local auto trader is full of 300Zs from the 90s for $5000 or less, and they are running. Nice 240 or 260Zs around here are usaully at least $3500, and certain things like brakes and suspension are going to be much better. The wiring portion may be a challenge (retaining the original dash/gauges), but the rest doesn't look so bad. I'm planning to get my feet wet on a 240Z first, but after that I may tackle a 300...likely with a blown or turboed LT1. Quote Link to comment Share on other sites More sharing options...
