l28et swap to 240z
I have done a search a couple times concerning this topic but I didn't find any thing really help full (might have done search right). I want to swap a 280zxt engine into my 240z. I have the full 280zxt car so I have the wiring, ecu ect... and I wanted to know if any one has written a step by step installation for swapping this (maybe, swapping for dummies)? If not I would love it if some one took the time to tell me what I should go about doing. Also could u tell me how much I could sell my 240 engine and trans. for, there out of a 72 w/ 134k miles. Any input would be greatly appreciated.
Guest michael_240Z
i myself will also most likely be doing the L28ET swap into my 73, if i don't get the opportunity to put an RB20DET in it first. i would have a shop do the RB install but if i got the L engine, i'd do it myself so i'd also like to see some detailed instructions and also the bugs and snags that one may encounter during the install.
hey gas, if the L24 is in good shape, usually $100 to $150 w/o carbs. the roundtop SUs by themselves can go from $50-over $100 a set depending on their condition. not sure about the tranny. i got an 83 five speed and a very nice R200 3.9 with the halfshafts for $175. hope that helps.
i myself will also most likely be doing the L28ET swap into my 73' date=' if i don't get the opportunity to put an RB20DET in it first. i would have a shop do the RB install but if i got the L engine, i'd do it myself so i'd also like to see some detailed instructions and also the bugs and snags that one may encounter during the install.
hey gas, if the L24 is in good shape, usually $100 to $150 w/o carbs. the roundtop SUs by themselves can go from $50-over $100 a set depending on their condition. not sure about the tranny. i got an 83 five speed and a very nice R200 3.9 with the halfshafts for $175. hope that helps.[/quote']
the 280ZXT swap is straight forward...only snag is drillin g ahole in the firewall and mounting the ecu and wiring it all up...i suck at wiring so i had a friend do it also, if you go with a stand alone its still smart to keep the wires in tact and not cut the harness...
http://www.zhome.com has 2 or 3 writeups on installing the L28ET
Heck, believe me I wasn't :D I checked out the site you posted because I am going to do the swap too, I saved everything there because I am used to broken links :(
haha good luck bro, if you want you can bring everything down in a weekend and i'll do the work but you gotta do the electrical because i suck at it =)
A word of advice, when you do the swap, while the engine is out move the battery to the back!! just makes moving around in the bay so much easier and gives the bay a cleaner look.
Thanx greatly for the links, they will come in verry handy and exactly what i wanted. but how would i go about moving the battery to the rear?
Guest zline
just get a summit battery relocation kit
