Guest Anonymous Posted February 23, 2003 Share Posted February 23, 2003 When there is no vacuum applied to an AAC valve, should the air passage be (more or less) air tight? If I put air pressure in a hose pressed against the pintile port, the air flows out the maniflod port, movement in the pintile makes little difference to the amount of air I can blow through the valve's ports. The diaphragm holds vacuum but the pintile doesn't seal the passage do I need to replace the aac valve? Dan Quote Link to comment Share on other sites More sharing options...
