Please help us Grumpyvette.
Guest RXO510
Guest RXO510
Please help us determine how Gabe's engine setup is. I pretty much went with reading many of the posts here. This is how I set up Gabe's engine.
383 sbc,9.0 - 1 Holley 650 DP, Edelbrock RPM Performer intake mani, hyd cam and lifters: int dur. 274, int lift .487; exh dur 286, exh lift .490 lobe 110 valves 2.02 and 1.6.
Block huggers dual 2.5" to an X pipe to a 3.5 " flowmaster 2 chamber.(changing to dual mufflers soon.) Very healthy sounding for sure. LOUD
All input, suggestions, changes are welcome. Please let us know. We will be adding NOS later.
Thanks twak.gif J & G
there is really not enough info here that can be used for a valid comparison of the listed parts you will need to list the type of cylinder heads , the port size if known, the brand of cam (altho the specs, match the comp cams xe274h)or the timeing figures and if you want the best guess at improvements the amount of nitrious (100-200-300 hp ) you want to use and the piston material(forged, cast , hypereutectic) plus rod length.and rocker are ratio. the transmission type and rear gear ratio, car weight, and intended use would help to,
Guest RXO510
Oh sorry about that Grumpyvette. Let me get all that info for you. I only gave you what I had remembered. Let me ask my friend at the shop about all the specifics you asked for. Will be getting back to you. Thank you. J & G twak.gif
