Arif Posted March 4, 2003 Share Posted March 4, 2003 How did you fit those 235x45x17 on your Z? If you used spacers (I am sure you did) how thick were they? I am about to purchase rims that are 17x7.5 with a 40mm backspacing (Honda type rims) and am looking for the right tires that would fit. I did a search and your rims were the closest in size not on a ZX. Are you running the same size on the fronts as well? I was looking at 215x45x17 Kumhos but didn't know 235s would fit which would give me a greater contact patch. BTW I don't have coilovers either. Quote Link to comment Share on other sites More sharing options...
Guest sb400z Posted March 4, 2003 Share Posted March 4, 2003 If you have coilovers you should be able to fit 235's fairly easily. Ross has honda adapters that are made for 40mm offset honda rims. Try emailing him. Good luck. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted March 5, 2003 Share Posted March 5, 2003 The spacers are 1 1/4" two peice 5 lug style. Although I have 200lb spring coilovers, they DO touch every now and then. Quote Link to comment Share on other sites More sharing options...
