Guest Anonymous Posted March 9, 2003 Share Posted March 9, 2003 Hi Guys, I have problem.... my flywheel center (hole) is too small to go over my crank. the flywheel from a 1987 chevy camro. the engine is a "target master" 350 4-bolt (1979-83) Thanks guys Quote Link to comment Share on other sites More sharing options...
Guest TBroZ Posted March 9, 2003 Share Posted March 9, 2003 This doesn't confirm which one you need, but my 327 Target Master took a 153 tooth flywheel. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 9, 2003 Share Posted March 9, 2003 youve got alter modr one piece flywheel, its prob 153 since if from a camaro, you need the early flywheel, for a two piece rear main seal motor, and since you prob got a 153 tooth starter ask for a flywheel for a 82 305 camaro, Quote Link to comment Share on other sites More sharing options...
383 240z Posted March 9, 2003 Share Posted March 9, 2003 the tooth count MUST match your starter the hub was changed when GM went to the one piece rear main seal. the tooth count has nothing to do with this change. your motor is of the 2 piece style Keith Quote Link to comment Share on other sites More sharing options...
