Guest Big Phil Posted March 10, 2003 Share Posted March 10, 2003 Tim, I know you disabled your VATS on your LT1. Could you help me disable mine. I plan on running all the smog equipment but the VATS has got to go. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted March 10, 2003 Share Posted March 10, 2003 Phil, Funny thing with mine, the VATS didn't stop me from starting the engine?!? But I disabled it in the PCM anyway. I use TunerCat. Also, although you are running all the smog stuff, TunerCat allows you to change the RPMs at which the EGR 'comes on'. I changed mine to 6700RPM, so it won't come on since it's rev limited at that point. I don't know why the VATS didn't stop me from running the engine, maybe it's the way I wired it up? Tim Quote Link to comment Share on other sites More sharing options...
