stage 3 or 5 turbine wheel
Doug71zt
I'm getting close to ordering a new hybrid. I'm set on the TO4E 60 trim compressor but unsure about the turbine wheel. Either a GT stage 3 or 5 is the option. Any feedback from people running either would be helpful. I run the car on the street, track days and the ocasional strip day. I would like to have boost up at around 2.7-3K and max boost right now will be 15PSI. I don't run it past 6-6.5K - no point till I change cams. Let's hear some opinions. I need something to think about now that I'm back at work in good ol' Baghdad.
Cheers - Doug
Guest Zcarsmakemyheadhurt
I have used both wheels and on a E I would go stage III you will love how the boost comes in and the TO4E compressor wheel should make 400hp. I use a .63 stage V now and its not the way to go on a .63, need to step it up. Good luck, stay out of the sand.
