260ZRED Posted March 16, 2003 Share Posted March 16, 2003 Whenever I start up the car, I can clearly hear a tiny but persistant beeeep beeeep noise coming from the dashboard... what can this be? its not really a big problem but its just something I want to get rid off! Any idea of where that bastard speaker is? I have no idea of where to even begin looking... Quote Link to comment Share on other sites More sharing options...
jimzdat Posted March 16, 2003 Share Posted March 16, 2003 IIRC the noisebox is under/behind the dash, just below where the dash light resistor switch is--kinda a pain to get to. Has 2 terminals on top You can either unplug the box, or the 2 small wires that go up to the ignition switch--it sounds like the key buzzer switch is FUBAR, and making the buzer stay on maybe? Quote Link to comment Share on other sites More sharing options...
260ZRED Posted March 17, 2003 Author Share Posted March 17, 2003 what exactly do you mean??? can you give me the exact direction where this bastard is? is it on the right or left at least? all my switches are being 'relocated' so i can't go by that... i'll try to find it again tommorow. Quote Link to comment Share on other sites More sharing options...
jimzdat Posted March 17, 2003 Share Posted March 17, 2003 oops--guess that would help, huh? Mine was on the left side--at the bottom of the dash, the steel frame forms a little "shelf" along the bottom edge--there is a small box mounted on top of it, midway between the column and the door jamb--should have 2 wires connected to the top of it (I think they are red/white, fairly small gauge wires, but not sure)--unplug that and it will shut up. Or, you can remove the plastic cover from the bottom of the steering column to expose the ignition switch--there is the main harness that plugs into the back of it, and a smaller harness that attaches to the side, towards the end where you put the key in (again, you'll see those red wires)--unplug that and it'll have the same effect--there is a small switch inside the ignition assembly that tells the car when the key is in the ignition and the door is open--either the switch in the ignition is screwed up, or the secondary circuit on your door switch is grounded (there are actually 2 switches built into the drivers door pin switch--but that wiring is even harder to get to) I'd try and get pics for you, but my car is in a million pieces right now, so it wouldnt help Jim Quote Link to comment Share on other sites More sharing options...
260ZRED Posted March 17, 2003 Author Share Posted March 17, 2003 thanks, i will go after that bastard after i get my gasoline leak fixed... right now i get less then a mile a gallon! Quote Link to comment Share on other sites More sharing options...
