python fuel injectors
fl327
I had a problem with the first set I bought. One ore more were slowly failing. I returned them under warranty for a new set. I didn't have problems with those for over a year. I then upgradded to bigger injectors because I am running more boost.
I reccomend getting some used OEM injectors, and having them cleaned and reconditioned. I just had a set done for $90.
BTW, Sherco is selling aftermarket (not OEM) 280ZX injectors made by RAM for cheap money. From what I've heard, the RAM injectors are so-so, but for the money, it might be worth the gamble.
http://www.sherco-auto.com/
Pete
  • 1 month later...
Guest Zcarsmakemyheadhurt
Injectors are the most important thing. If one or two or a set fail your done and I have seen it happen. I use O-ring style Ford injectors they very from 19-73lb and do require a fuel rail. You can and should pick up Bosch units for a stock replacement. If your upgrading the fuel computer go O-ring. Good luck.
