Guest Anonymous Posted April 1, 2003 Share Posted April 1, 2003 is this kit even made anymore? also, what headlights do you all think would look good molded into the front? maybe some photoshop experts can post a pic? i really like those flares.. Quote Link to comment Share on other sites More sharing options...
John Washington Posted April 2, 2003 Share Posted April 2, 2003 Check out my website at http://www.reactionresearch.com . Click on "automotive." If you look at the photos of Ted Fisher's car at the car show, you can see a great way to mount lights on the kit. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 2, 2003 Share Posted April 2, 2003 Hi John, that car is simply amazing. Would you happen to know the specs on those wheels? Make, offset, width, etc? I did see the positioning of those lights, but I was hoping to do a different setup. I'd like to have the lights in the actual body.. If this is possible, then I would like to purchase the kit considering everything goes ok with my shell. there is quite a bit of rust and if it is still salvageable, i'm buying that kit. So, if the hood is not included, is the stock one usable? Thanks for your time, Jason Quote Link to comment Share on other sites More sharing options...
zlalomz Posted April 3, 2003 Share Posted April 3, 2003 I talked to Ted Fisher about his wheels. They are 18x12 Complete Custom wheels. 5 1/2 inch backspacing with 1/2 inch spacers up front. Yes 18X12. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 3, 2003 Share Posted April 3, 2003 wow.. 12"??? that must be a wiiiiiide kit =) does anyone know the brand of wheels those are? or, a similar type rim.. i think image wheels in england has a similar rim. here is the pic that looks somewhat similar. btw, is he running a stock motor with triple carbs? i wonder how much power his setup produces... i love that car. i wish i had one Quote Link to comment Share on other sites More sharing options...
John Washington Posted April 3, 2003 Share Posted April 3, 2003 I've talked to several guys over the years about using a hole saw to cut a hole right in the front of what would otherwise be the headlight area, so as to mount a small-diameter round projector-beam light. I think that would look really cool. Maybe someone with Photoshop (who is better at it than I am) could cobble up a rendering. If you look at Ted's car at http://www.reactionresearch.com/Fisher/index.htm you will see his triple carb setup. I don't know the exact details of his engine, but as I recall he's over 300hp. He owns Primarily Japanese auto service in Tucson, so he knows a trick or two. That car really scoots around the track...seen it in person. Ted is a dealer for those wheels. Jason, where are you located? I offer donor sourcing service and if you have more than a couple thousand bucks worth of rust repair to do, you should consider getting an AZ car. Even with the transport cost, you may come out well ahead. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 3, 2003 Share Posted April 3, 2003 i like these rims: http://www.fikse.com/fm10.html anyway, John, I am located in Houston, TX. I still haven't taken the car to my friend who owns a body shop. If he can patch up the car for a reasonable price, I will probably keep it. he only requires that I get it running, which i havent even begun to do. I just purchased it a little while ago and got a public storage place for it. my car is an automatic, but i'd like to get a 5spd. so.. if you can find an AZ car that is 5spd with a good running motor, i might be able to sell this one and get one from you. i'll purcase the 280YZ kit while i'm at it. i wouldnt be able to afford the rims or anything else though! let me know. Quote Link to comment Share on other sites More sharing options...
John Washington Posted April 3, 2003 Share Posted April 3, 2003 Give me some idea of what you want, equipment, condition, running/not, budget, etc., and I'll see what I can do! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 3, 2003 Share Posted April 3, 2003 John, I sent you a PM Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 12, 2003 Share Posted April 12, 2003 do the 280yz pannels replace the old 1/4 pannels or just bond on top of them? Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted April 12, 2003 Share Posted April 12, 2003 They bond to the sheetmetal but you need to cut out your wheel wells to take advantage of the extra space for the big tires. Take a look below. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 14, 2003 Share Posted April 14, 2003 is the whole kit like that? I like the look of some of the glass bodies but more than looks I want to reduce weight. does anyone know anything about stand alone glass panels? Quote Link to comment Share on other sites More sharing options...
John Washington Posted April 18, 2003 Share Posted April 18, 2003 Just to be clear, the front fenders, air dam, and hood REPLACE existing sheet metal for a weight savings of more than 50%. The rear quarters bond on over existing rear quarters, after trimming them out for the larger wheels and tires. There is a VERY SMALL weight increase in the rear. The original rear quarters can be removed for racing style application. However, in most cases the weight savings are not worth the structural integrity degredation of removing that panel. The rear quarters on virtually any unibody car (like all Zs) is part of the structure of the car. You can find all this information on my website on the FAQs page. Quote Link to comment Share on other sites More sharing options...
zhins50 Posted April 22, 2003 Share Posted April 22, 2003 if you can afford them bmw z8 Quote Link to comment Share on other sites More sharing options...
John Washington Posted August 10, 2003 Share Posted August 10, 2003 >if you can afford them bmw z8 Huh? I mentioned earlier in the thread the possibility of mounting projector lights. Someone sent me this picture last night: http://www.reactionresearch.com/280yz/projectorlights.html Quote Link to comment Share on other sites More sharing options...
Guest 70240z Posted September 2, 2003 Share Posted September 2, 2003 Anyone in the Bay area getting this kit anytime soon?? Quote Link to comment Share on other sites More sharing options...
zlalomz Posted September 2, 2003 Share Posted September 2, 2003 Darius in the east bay has the 280YZ kit and has some pics on his website. I have the kit in Sacramento with pics in my personal gallery. Quote Link to comment Share on other sites More sharing options...
JaysZ Posted November 15, 2004 Share Posted November 15, 2004 does anyone think having the rear only would look funny? Quote Link to comment Share on other sites More sharing options...
zlalomz Posted November 16, 2004 Share Posted November 16, 2004 It would kind of look like J-Lo. You woud have a 7 inch max front tire with up to a 12 in the rear. For a more balanced car I would look at Dan Juday's use of the subtle Z front fender's with the YZ rear. Quote Link to comment Share on other sites More sharing options...
JaysZ Posted November 17, 2004 Share Posted November 17, 2004 yeah i thought so too :/ lol. just for reference, what does darius use up front? i see the YZ in the back but its hard to tell whats in the front. YZ as well? I'll probably go the subtle Z route Quote Link to comment Share on other sites More sharing options...
