best L28 setup
Let me start by saying thank you to all who helped me with my broken head bolts. I discoverd that the person that owned the car before me hurt it bad and did some nasty Rednecking on it when i got the easy out drilled out finaly i know why it broke they had put lock tight in the stud. WOW!anyway there is a nasty crack from the bolt hole to the cylender this was the first time that i have had the head off. Also i moved #1 piston and the cylender was cracked badly not to mention the rust around all of them so i need a new block! Let me get on with it Found a newer Z that was wrecked motor is complete but fuel injected do es it have to stay that way because i have a new weber setup snd would like to use it thanks for the time and patience reading all that :twisted:
