Stock boost increase?
How do you increse the boost on a stock 280zx? Do you completely remove the pop-off valve? Or is a boost controller in order. I can make one right?
You could thread the rod on the wastegate actuator. That will allow you to change the tension on the diaphram, or use a bleeder valve, or do a ball/spring type valve. Any of these you can do yourself. If you only want to turn up the boost a few lbs, then I would go with threading the wastegate rod or using the wastegate from an 8_-89 300zx turbo as I believe they were already threaded. When you do start turning up the boost, do it slowly so your pistons and rings don't go BOOM!
