Guest Anonymous Posted April 9, 2003 Share Posted April 9, 2003 Got my new block in today noticed that the car is able to roll when in gear so i check its in gear get in step on the clutch go through the gears and then (clunk) its fine car dosent move go to step on clutch again and it is rock hard aplly a little presure and then (clunk) same strange noise now there is fluid poring out of the side of the bell housing and the clutch peadel goes all the way to the floor real slopy and lose i need help what is this did i do something wrong or did i not do something i was suposed everything lined up when i put the block in Quote Link to comment Share on other sites More sharing options...
j260z Posted April 9, 2003 Share Posted April 9, 2003 sounds like you're slave cylinder is leaking for one. check and see if the pushrod on the slave cylinder is still seated on the withdrawal lever on the side of the bell housing. i would check that first. Quote Link to comment Share on other sites More sharing options...
