john kosmatka Posted April 10, 2003 Share Posted April 10, 2003 I was wondering, what are all the the major modifications do you have to make to do this swap. Refering to the wiring harness, ecu, transmission and fuel delivery. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted April 10, 2003 Share Posted April 10, 2003 I have to tell you that I found a wealth of information on the turbo swap at http://www.zcar.com Those guys have been doing this for a long time, and a lot of the same guys are here on hybridz, but hybridz has a lot more info pertaining to the V8 swap than the turbo swap. Just search in their 70-83 tech area and search mainly for "turbo 240" or "L28ET 240" etc... Look at these two posts from zcar: http://http:/www.zcar.com/forums/read.php?f=1&i=191232&t=191088 http://http:/www.zcar.com/forums/read.php?f=1&i=173712&t=173582 Hope that helps Quote Link to comment Share on other sites More sharing options...
mobythevan Posted April 10, 2003 Share Posted April 10, 2003 http://www.zcar.com/forums/read.php?f=1&i=191232&t=191088 http://www.zcar.com/forums/read.php?f=1&i=173712&t=173582 Quote Link to comment Share on other sites More sharing options...
Mudge Posted April 10, 2003 Share Posted April 10, 2003 Zcar is a great site, alot of the guys there are really helpfull and know these cars well. Quote Link to comment Share on other sites More sharing options...
icice9 Posted April 11, 2003 Share Posted April 11, 2003 ive got prett much the same problem but i need to change my rear main seal... ijst wanted to know if its as easy as haging the front.. i know i have to pull the tranny out and the fly wheel.. so is it the same process? Quote Link to comment Share on other sites More sharing options...
Mudge Posted April 11, 2003 Share Posted April 11, 2003 Basically yeah, fetching it out might be "fun," putting it back should be pretty easy. Use asm lube or 30w oil and it should slip on fairly easily, you can use PVC pipe instead of a rear main installer if you can find one in the right size. Quote Link to comment Share on other sites More sharing options...
john kosmatka Posted April 11, 2003 Author Share Posted April 11, 2003 I am having a second thought about this swap, I am in the process of acquiring a 83' zx turbo. I am thinking about just keeping the zxt and restoring the 76' to orriginal and before I decided I wanted to know if the handling of the zxt is any better than the earlier Z's. And if the suspension has more potential for modifications than the earlier Z's. Thanks for your help, John Quote Link to comment Share on other sites More sharing options...
Jwink25 Posted April 11, 2003 Share Posted April 11, 2003 Those articles were great reading. Thanks, Jason Quote Link to comment Share on other sites More sharing options...
