Question on 280zx turbo motor into 76' Z
I have to tell you that I found a wealth of information on the turbo swap at http://www.zcar.com Those guys have been doing this for a long time, and a lot of the same guys are here on hybridz, but hybridz has a lot more info pertaining to the V8 swap than the turbo swap.
Just search in their 70-83 tech area and search mainly for "turbo 240" or "L28ET 240" etc...
Look at these two posts from zcar:
http://http:/www.zcar.com/forums/read.php?f=1&i=191232&t=191088
http://http:/www.zcar.com/forums/read.php?f=1&i=173712&t=173582
Hope that helps
ive got prett much the same problem but i need to change my rear main seal... ijst wanted to know if its as easy as haging the front.. i know i have to pull the tranny out and the fly wheel.. so is it the same process?
Basically yeah, fetching it out might be "fun," putting it back should be pretty easy. Use asm lube or 30w oil and it should slip on fairly easily, you can use PVC pipe instead of a rear main installer if you can find one in the right size.
I am having a second thought about this swap, I am in the process of acquiring a 83' zx turbo. I am thinking about just keeping the zxt and restoring the 76' to orriginal and before I decided I wanted to know if the handling of the zxt is any better than the earlier Z's. And if the suspension has more potential for modifications than the earlier Z's.
Thanks for your help,
John
