wiring up
I have everything out of an 81 ZXT wiring,motor,etc. Everyone is telling me to use the 82-83 wiring harness and stuff, well can I still use the 81 wiring harness and just swap in the 82/83 distributor? I have seen this dizzy and it looks like the black plastic plug is the same, going to the crank sensor in the 81, and the dizzy sensor in the later.
No, the pinout is not the same, so you'd have to swap some things around. The CPS in the distributor does not rotate the same # of counts as the crank version either, so there is another problem.
The 82+ harness is more "contained" is the only reason, just use your 81 stuff IMO, or else expect to do a complete conversion.
