shortened driveshaft fits C4 and T5?
If I go with an auto can I switch to a man and still use the same shaft?
Are a C4 and a T5 the same length? just trying to decide what I want to do.
there are a lot of autos cheap but I love the manual with that top gear
and what it does to shorten those midnight runs
This is not really what you are asking but with a rough measurement I made on my T5 it is the same length as the AOD I am putting in. If you want I can measure a C4 I have also. You see I wasn't sure which tranny I wanted to run so I have all three to cover my bases. :wink:
Don
that would be wonderful! my main reason for wanting to be able to switch is that I have a habit of destroying at least one clutch a year Clutch life varies of course.... depending on my level of "ENTHUSIASM"
but its very possible that i might want to change the trans, maybe just for a change of if its not to complicated or takes a different drive shaft or something can you measure the T 5 for me and give me the numbers?
