cv install?
Guest 2002sentraSER
if you're putting the cv's in with the r200 at the same time then on top of the parts for the diff swap you will also need a set of adapters for your companion flanges. you can find them here http://www.modern-motorsports.com/catalog/product_info.php?manufacturers_id=&products_id=5 :-D
then if you are looking to do a brake upgrade you should steal the front calipers off your wifes vehicle and get these parts here http://www.modern-motorsports.com/catalog/product_info.php?manufacturers_id=&products_id=48 :D
