ToplessZ Posted April 21, 2003 Share Posted April 21, 2003 I have some good interior pieces that have been oversprayed on and Id like to know how to clean them up if anyone knows that would be great. Thanks Quote Link to comment Share on other sites More sharing options...
Guest Zachb55 Posted April 22, 2003 Share Posted April 22, 2003 I am a victim of this as well and could also use a bit of advice on what others have used.... Laquer Thinner takes the paint off but its slow and im sure its not good for the pieces, what about repainting? anyone know of a good dye or paint that is good for interior peices like that? -Zach Quote Link to comment Share on other sites More sharing options...
V8ZRACER260Z Posted April 22, 2003 Share Posted April 22, 2003 Do not use laquer thinner. It will attack the plastic & vinal pieces. Try a clay bar if the parts are smooth. there are several brands of overspray removal liquids out there like "Goof Off". These are primarily designed for exterior sufaces. Go to a reputable upholstry shop and they will have recommendations for you. More than likely they will need to be painted or redyed to remove all of it. Rick Quote Link to comment Share on other sites More sharing options...
DavyZ Posted April 22, 2003 Share Posted April 22, 2003 Rick's option is the only one that I know of that will work w/o hurting the vinyl. The other option is to cover the area up with SEM Landau black interior fabric and vinyl spray dye/paint. It looks 'stock' and is consistent in it's gloss, but be forewarned: your job is only as good as the prep work. Davy Quote Link to comment Share on other sites More sharing options...
DavyZ Posted April 22, 2003 Share Posted April 22, 2003 Ah, it always helps when a real PRO weighs in! Thanks for the help, Racer X!!!!! Davy Quote Link to comment Share on other sites More sharing options...
