Rod Bearings
Guest Russ240z
Guest Russ240z
I have a sbc 400 and need new rod bearings. The ones that I took out are Clevite/Michigan 77. I need to know if it is a standard size or .010 bearing so I can replace them. Here are the markings:
9 87
CB663P
F1
The "F1" is the part I don't understand. I have used all my sources and have had no luck. Any help you can offer is appreciated.
Russ
the smart way is to MEASURE THE CRANKSHAFT JOURNAL
but just for your info:look
http://members.aol.com/rovabr/bearings.html
CB663P =std CB663P10 =0.010 10thousands undersize
http://www.engineparts.com/products/HDBearings.html
http://www.engineparts.com/products/Bearings.html
http://www.engineparts.com/motorhead/techstuff/brgselec.html
