Guest storm280z Posted May 7, 2003 Share Posted May 7, 2003 my car will dies sometimes.i will be driving an the car will just shut off. but sometimes i can take the car out of gear an return the motor an it will start back up. an sometimes i have to stop an give to fusible link a good hit an it will start back up. the only noise it makes when it dyies is a click from around the fuse box. also sometimes when im driving it will die an start back up on its own butit will so it real fast. help . can it be my ignition relay/or my transistor igition unit Quote Link to comment Share on other sites More sharing options...
DavyZ Posted May 11, 2003 Share Posted May 11, 2003 It could be fuel or ignition. I had some strange problems with the car dying and such until I replaced the ignition module with another one--problem solved. Oh, and I was blowing fusable links too until I did that mod. Davy Quote Link to comment Share on other sites More sharing options...
Guest storm280z Posted May 12, 2003 Share Posted May 12, 2003 this might sound dumb but what happens when a fusible link is blown Quote Link to comment Share on other sites More sharing options...
fl327 Posted May 12, 2003 Share Posted May 12, 2003 when a link goes, you generally lose power to the key on position, which means the ecu will not fire and ignition wont get power, heres a weird one, nissan wired the links up so that the radio dies when a link goes, the efi link that is. i had this problem in my car and traced it back to a faulty fusible link, i also had bad battery leads too, when the link would go otu, my radio would go out too, but the lights would still be on, i just made another link, and it was good to go. Quote Link to comment Share on other sites More sharing options...
Guest toyotasupra17 Posted June 19, 2003 Share Posted June 19, 2003 ok dont laugh whats a fusible link ......i dont know whats happening to my car but ill try and explain.......ok i just recently purchased my first car for 150 and it happens to be a 1978 280z ....i have only driven it like 5 times so far and everyonce in a while when i turn the key it makes a grinding sound...will happen 1-3 times before the car starts, now this doesnt happen eveytime i start the car only sometimes.....next problem some times the idle goes way below 1k like around 500 but that also onlt happens once in a while.....i was driving the other day and all of a sudden the rpms dropped way down and the car shut off so i tried to start and wouldnt start for 10 mins of trying to start i could smell fuel when i was trying to start it.....next problem lol my radio worked then one day it didnt it was working fine then all of a sudden it just didnt work i changed the fuse and still nothing....and my last problem when i was driving and i turned to the left i got alot of wheel shake but it only happend like 3 times then stopped.........now can someone please help me out and let me know whats going on with my car she has 130k on her shes a 5sp and the body is in decent condition also can stock 280z's take 5.0 mustangs? cause alot of you say these cars feel sluggish but i think its fast as hell imo it roast's the tires like no other lol but all the help is appreciated Quote Link to comment Share on other sites More sharing options...
Guest torynich Posted June 19, 2003 Share Posted June 19, 2003 As for the wheel shake, check your wheel bearings. Also give a quick check to make sure your lug nuts are tight, I've done that one before and felt like a complete idiot when the rim came off... Quote Link to comment Share on other sites More sharing options...
innerware Posted June 19, 2003 Share Posted June 19, 2003 Wow, you have a list of things that need addressing I think. I was in your same shoes about a year and a half. Do your self a favor and clean the engine good. It will help you move around in it and look around easier. Check all your wire connections. I had to replace all my connection; ie, to the injectors, temp sendor, thermotime. There are more too, I just can't remember. Check your battery cables. Make sure the terminals are clean and the cables are attached well. The fuseable links are located on the passenger side of the car mounted infront of the battery. They are in two seperate pods. Maybe you still have the white covers over them. If they are old and haven't been replaced in a while (like ever) then they are sure to be brittle and may break if removed. Buy new ones and remove and check the links. They are just what they sound like. They are an old type of fuse. A bit of thick wire connecting two terminals. Check them and maybe replace. Most everything plastic in there is old and brittle by now. It is real frustrating but be patient. After I replaced plugs and connections my problems went away. The idle issue might be your BCDD valve. I am not sure what it means or what it does. I had that problem and was told that if I blocked it with a solid gasket that there would be no problem. I did that and my idle is good now. Maybe someone else can chime in. Just give it love and affection. Clean it real good and give it a full tune up. It is real easy. That is how I learned. Get the manual for the car. You can aquire one on cd from courtesynissan.com It is a real help and wan't all that expensive. Finding an actual real copy can be hard, and the cd version lets you print out just what section you need. I carry a binder with me in my car with all the chapters printed out. It has paid for itself. Good luck and have fun. Quote Link to comment Share on other sites More sharing options...
Guest toyotasupra17 Posted June 19, 2003 Share Posted June 19, 2003 i have all origional paper work all the warenty papers and factory handbook.....i am the second owner........where could i get those plastic covers? also im in need of a hood popper latch for the inside of the car and the intenna switch where is a good place to find interior parts and a place to find body parts? well i only paid 150.00 for the car got to expect something to be wrong but ill post uppicks sometime the paint on her almost looks brand new the car is in awsome shape had been sitting for a couple years put a battery in and started on second turn and first turn from there on but thankx for all the help Quote Link to comment Share on other sites More sharing options...
MAYHEM Posted June 19, 2003 Share Posted June 19, 2003 where is a good place to find interior parts and a place to find body parts? Try here http://www.victoriabritish.com/z_zx_cat_page.htm or you can upgrade to this http://shop.zcarcreations.com/display.asp?sku=26&rP=searching,cat@Electrical,cR@default look in the electrcial section for the MAXI fuse block Quote Link to comment Share on other sites More sharing options...
Guest Hceline17 Posted August 12, 2003 Share Posted August 12, 2003 Hey toyota, besides the new battery did you change fluids and spray some oil in the cylinders before you started that car for the first time in a couple years? If not you might be causing another whole host of problems... I don't have my Z yet, but knowing cars in general that's what I would say. Anyway, my suggestion is just like Innerware's give it a tune-up and some Tender-Loving-Care Quote Link to comment Share on other sites More sharing options...
