my brake upgrade!
hey all, just posted a few more pics. the project is coming to a close and i'm itching bad to check out the new binders. just have to bend 2 brake lines from the factory junction block to the new tilton master cylinders, bleed the masters and brakes then...drive and bed in the brakes. below is a link to my pic gallery. i went a step further than originally planned when i contacted ross corrigan at http://www.modern-motorsports.com. i added tilton separate master cylinders as well as a cable operated mechanical brake bias. the kit ross sold me when together without a hitch. this is probably the first time in quite awhile that i purchased something that came with all the parts i needed; bolts, washers, cotter pins, everything. it was nice for a change not to have to chase down odd parts or hardware here or there. i used his 13" vented rotors with 2 piston alum. pbr calipers up front and the 11" solid rotors with 240sx calipers in the rear. i also retained my parking brake-as this is a street car! anyway, more one i have it on the road and am able to throw out the anchor and really test the binders!
http://www.classiczcars.com/photopost/showgallery.php?ppuser=1750&cat=500&thumb=1
  • 3 weeks later...
just got the z down on all 4's last nite and did a quickie alignment [enuf to at least get it to the alignment shop w/o completely knocking all the tread off the new meats-yoko 235/40/17's!!]. i completely forgot about no more vacuum assist and nearly plowed thru the back of my garage. amazing the strength u can muster when absolutely necessary. anyway, got some used arizona z rear control arms, mike kelly front control arms & t/c rods and ross corrigan's big brakes all around. i had hoped to run in the auto-x this sunday but the wait at dmv to get my plates out of storage was more than 1 1/5 hours! so the 2+2 zxt will have to stand in. i should have it aligned wed next week and be able to bed in the brakes and really throw out the anchor and see how the brakes & new suspension work. oh, any tips on alignment are always appreciated. john coffey has given me some valuable input-thanks john!
