1 tuff z Posted May 8, 2003 Share Posted May 8, 2003 hey all, just posted a few more pics. the project is coming to a close and i'm itching bad to check out the new binders. just have to bend 2 brake lines from the factory junction block to the new tilton master cylinders, bleed the masters and brakes then...drive and bed in the brakes. below is a link to my pic gallery. i went a step further than originally planned when i contacted ross corrigan at http://www.modern-motorsports.com. i added tilton separate master cylinders as well as a cable operated mechanical brake bias. the kit ross sold me when together without a hitch. this is probably the first time in quite awhile that i purchased something that came with all the parts i needed; bolts, washers, cotter pins, everything. it was nice for a change not to have to chase down odd parts or hardware here or there. i used his 13" vented rotors with 2 piston alum. pbr calipers up front and the 11" solid rotors with 240sx calipers in the rear. i also retained my parking brake-as this is a street car! anyway, more one i have it on the road and am able to throw out the anchor and really test the binders! http://www.classiczcars.com/photopost/showgallery.php?ppuser=1750&cat=500&thumb=1 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 8, 2003 Share Posted May 8, 2003 Very nice. That should stop the car over and over and over....... Quote Link to comment Share on other sites More sharing options...
1 tuff z Posted May 24, 2003 Author Share Posted May 24, 2003 just got the z down on all 4's last nite and did a quickie alignment [enuf to at least get it to the alignment shop w/o completely knocking all the tread off the new meats-yoko 235/40/17's!!]. i completely forgot about no more vacuum assist and nearly plowed thru the back of my garage. amazing the strength u can muster when absolutely necessary. anyway, got some used arizona z rear control arms, mike kelly front control arms & t/c rods and ross corrigan's big brakes all around. i had hoped to run in the auto-x this sunday but the wait at dmv to get my plates out of storage was more than 1 1/5 hours! so the 2+2 zxt will have to stand in. i should have it aligned wed next week and be able to bed in the brakes and really throw out the anchor and see how the brakes & new suspension work. oh, any tips on alignment are always appreciated. john coffey has given me some valuable input-thanks john! Quote Link to comment Share on other sites More sharing options...
